Hi, I have a 1986 90hp Evinrude without temperature gauge (no way to now if the motor is to hot). I notice that the water coming out thru the pee hole was to cold and on 5000 rpm, the pee pressure will lose a lot of pressure, I change the impeller no luck, so I decide to check the thermostat and there was no thermostat, when install new thermostat the pee pressure was low for about 30 seconds then a get a very strong pressure thru the pee hole, the highest I go on RPM the strongest the pee pressure is. But the problem that I gat now is that before I can touch the Motor head with my hands and they wore cold now they are two hot for my hand I can only leave my hand for about 15 seconds before I get burns and Im afraid that the motor is running to hot. My question is: Can run this motor without thermostat or they have to have thermostat? Since I dont have a pressure gauge and afraid of overheating the motor..<br />I really appreciate any help.<br />Thank you
