EricJRW
- Joined
- Feb 3, 2010
- 488
1993 50 HP Evinrude, model VE50TLETF.
Worked last year, started flaking out this year. Reservoir is topped up. Tilt motor spins... Sounds like fluid is moving. If I help it up, by lifting while using power tilt, it will raise and stay in place. Underway trim does not work (engine does stay in place though), but if I come to a stop it does work (to a small extent). For now I'm leaving it down.
Seems to me pump is not generating enough pressure. Is this a good assumption? Is this something that can be tested? Rebuilt?
Thank you in advance for your help.
Eric
Eric
