Evinrude, can you identify year form these numbers?
Mike Ku
I have an older Evinrude outboard. On the side of the mounting bracket and on the side of the cylinder case on a small aluminum plug, I located these numbers. They are the same in both locations: 15020 26861 The cover on the motor says: "Evinrude Fastwin 18" Can you tell me the year and, pardon the ignorance, but is it an 18hp? Thanks!!! :)
fone_man
Re: Evinrude, can you identify year form these numbers?
Model #: 15020<br />HP: 18 <br />Year: 1957 <br /><br /> :cool:
riverrat07
5.7 Mercruiser-No Fire
Running fine yesterday - no fire today.
Checked postive side of coil with key in on position 12.5V.
Checked the white/red wire had 11.5V.
Removed the coil wire inserted spark gap tester.
Removed the white/green wire from the distributor put key in on position and grounded the white/green lead, no spark at coil.
Put a new coil repeated test same results! Also, checked neutral interupt switch, ok! Also, checked tact - ok!
Is there anything else that would cause no fire?
riverrat07
5.7 Mercruiser-No Fire!
HighTrim
No spark is usually problematic of
1. Sensor coil
2. Charge coil
3. Power Pack
4. Key Switch
5. 10 way connector
although i am unfamiliar with the older motors
F_R
Riverrat, you are breaking into somebody else's thread. Please start your own. In fact I belive you are not even on the correct forum for a mercruiser.
Java
Hi,
I can't help you but could you tell me how to post to this forum?
Thanks Java
jjwg03@yahoo.com
david_r
java look at the top of the topics and click on "create new post"
