Evinrude carburetors compatibility?
alexsails
Hi everyone, I need to replace the carbs on my 1988 200hp evinrure and have found a possible match. Before I make the purchase I need to know if the ones being offered will work on my engine.
They are off a 1990 evinrure complete set with throttle bodies. I have compared photo details carefully and look exactly the same.
Does anyone know what years of evinrude carbs are compatible, or if the ones offered to me (1990) will fit?
thanks!
Faztbullet
Re: Evinrude carburetors compatibility?
Johnson/Evinrude looper carbs will interchange from 1988 to 1994 as these have the fixed idle and midange jets. In 1994 thru late 1999 all had the adjustable needle and in 97-99 200hp's they went to a small bore carb. Make sure the carbs have the correct high speed jets in them. If you can find a set a 225 carbs(94& up) install them and enjoy the extra hp!!! I am running the 250hp V-8 carbs on my V-6!!!
