Re: evinrude down trim help
fds,If you have three wires coming from your trim motor , you may not have reversing feed relays.The 1980 model T/T motor is three lead.If you can separate these three wires and determine the two positive and one ground ,you can perform a 12v test to see if motor works in both directions.Jumper a pos and neg lead to one pos and neg and observe motor operation.Then , attach the positive jumper to the other pos lead and observe if motor operates in other direction.The 1980 T/T motor is fed through a solenoid.You'll need to locate this component and inspect wire leads and test for operation.If the solenoid checks out ,your problem is either switch or wiring related.
