Evinrude e-tec or Yamaha 4 Stroke
seahorse5
Re: Evinrude e-tec or Yamaha 4 Stroke
Not commenting on the E-TECH oil useage, but the NMMA figures show less than 50 hrs use on a nationwide average per season. The EPA and CARB use a 35 hr. annual use when setting up emission specs. That's why the motors have to meet specs for only 350 hours. The 4-strokers love that figure since a 4-stroke pollutes more as the rings, valve guides, seals, etc. wear from use.
rodbolt
hello<br /> gotta agree with ya seahorse. the guys that dont use the motor get the best warrenty value. and there is a lot of odds playing with warrenty. as far as rcupp its irrelavent its a two stroke and must burn a portion of its lubricating oil to stay alive. even the hypester that wrote the letter agreed with that. and it takes X amount of fuel to make X amount of horsepower so That is what I am basing the oil consumption onto make two hundred prop shaft horse power will require at least 18 gallons of fuel per hour. I cannot remember all the specs but its in the engineeing handbook. look it up if ya dare.<br /> High pressure direct injection is not new. its proven that it works. its the method used. a lot of consumers have been roasted on all this new tech stuff.all the DFI hype and 4 stroke hype is killing me. the sales people throw about words like NASA and space age and High tech million gigabit eyeglazer technology and it will cook breakfast on saturdays with an optional upgrade to dishwashing. all I want to see is does it work in the real world. testing on a bass boat at the boat show is not the same as the guy that is trying to water ski pull nets and generally neglect it. it is true that high pressuere ful in the rails does not go bad like fuel in a fuel bowl.but I worry about the hype of no scheduled maint for three years when I have most customers run 500 hours or more a year.I have already seen a post here where someone claimed he would not have to check the oil for 3 years.my only concern is the old saying when I was drag racing heads up. the BS stops when the green flag drops:) :) <br /> yall have a nice day now ya heahs
jegervais
Forktail,<br /><br />I have several technical and theory-based books regarding props and propping from Mercury, OMC and I think I've got one from Yamaha kicking around too. A couple of them discuss the "adding cup" to the trailing edge and/or to the tip of the prop blade and how it effects the average pitch of the blades and ultimately the crafts overall performance. If you would like to read them I can send them to you. I don't have a scanner, but I would be willing to fax you if you want.<br /><br />Let me know.<br /><br />-John
Forktail
Ensign
Thanks so much John. :) I have plenty of propping reference here. I am very familiar with the effects of cupping and pitch.<br /><br />Cupping can't change pitch. A 15 pitch prop is a 15 pitch prop, whether it is cupped or not. Pitch is only concerned with the distance the propeller moves through the water in one revolultion, with zero slip.<br /><br />The goal with added cupping (for some hulls), is to reduce prop slip, because all propellers will have slip. The more that slip is reduced, the closer to the actual prop pitch stamped on the propeller we get. Only in a perfect theoretical world will a 15 pitch prop move through the water 15 inches per revolution. <br /><br />Cupping can reduce slip by reducing ventilation (sometimes called cavitation). It can also allow for more bow lift which causes less hull surface to be on the water, thus having less force to push against. There are other benefits too for some hulls, but all the cupping in the world can't make a 15 pitch prop move through the water more than 15 inches per revolution.<br /><br />That article posted on the E-Tech made it clear to me that the engine is designed for the weekend warrior, not the heavy duty or commercial user. Emissions seem to be the reason for it's design, not durability.
honda cat
what we read in all those boating magazines does not seem to all ways work out quite the way it did when the magazine tested it ect. <br /><br />The technology we are dealing with here changes almost on a daily baisis what was true yesterday has changed today . Who knows about e tech? i have run one at the dealer show sure runs great! but so did the 1999 fitchs this looks like just another generation of the same thing and i am sure that there has been many improvements made.<br /> One thing that has come along recently that has impressed me is the new 135/150 Honda i got to run a couple of them on diferent kind of boats at the honda dealer show in florida a month back . and the HOLE SHOT was unbeliveable and is lighter than their old style 115hp . Better than most carb 2 strokes that i can ever remember and at the very least compairable with the new DI out boards . Its makes a bunch of the old facts on four strokes obsolete and deserves a look!<br /> and the bombardier family only owns 50% of the company whitch i find verry unseteleing The other half is owned by a investor group .cant remember the name but it is the same one that ownes the STAPLES chain of ofice suply stores as far as anyone i have asked they have little or no back roud in tme marine industry whitch sounds like the deal Where MR SORROWS bought the old omc the first time i belive he was in the apliance buisness . not to mention that no one has the deciding majority of stock in this new company and this also is scary sounds to me like a new level of corporate in decision
Tracy Coleman
Thought I read somewhere that the Bombardier family holds like 65% of the voting stock. ?<br />When a prop varies in "pitch" from hub to blade tip, how do you measure "theoretical pitch" and is this different from "actual pitch"? If the pitch progression, different at each point of measurement is averaged,is this "assigned pitch"? <br />Knowing that blade contact area is subject to a wide variety of differing load forces-soft water, hard water, etc...,can a certain formula be used to weight the most effective area? Since todays manufacturers employ mostly new "modern" prop technology, is there a standard by which all props are rated/measured?, or do the mfgs stamp a figure on their props that is their assessment devoid of any benchmark or standard? The fact is that there is a great difference in performance between props of the same pitch. I call 1-4+ mph a great difference concidering the hp needed to produce results like this. If two devices are the "same" but produce different results, what accounting procedure do we subscribe to? So many questions and we haven't even got to the Helmholtz resonator.<br />Backfire ;)
Tracy Coleman
PROPELLERS <br />Propeller Selection <br />It is important to you, as a boater, to understand the basics of propellers. This will enable you to determine the propeller that is best suited for your application. The following is only a guide; to save time, ask your marine dealer or boat manufacturer for advice on selecting a propeller. <br /><br />The propeller on your outboard motor is the means by which the horsepower, developed by the engine, is converted into thrust to propel your boat. As such, its care and selection is very important to insure continuous service and satisfactory performance. <br /><br />Several propeller options are available to you, if you want to change your performance for better top end speed or to increase load carrying performance. <br /><br />Materials <br />Composite and plastic propellers are generally used for emergency situations. Aluminum propellers, being the most common, have reasonable durability for most applications. <br /><br />Stainless steel propellers are stronger than most all other propeller materials. Some advantages are longer life and high hydrodynamic efficiency derived from stiffer blades. <br /><br />Diameter <br />Diameter is simply the width of the circle described by the rotating blades. <br /><br /> <br /><br />Pitch <br />Pitch is the angle of the blades expressed in inches of theoretical travel in one revolution of the propeller. This propeller has a pitch that will theoretically result in 24in. of forward travel in one revolution. In use, the propeller experiences slippage so that its actual travel per revolution is less than the stated pitch. <br /><br /> <br /><br />Rake <br />Rake is the measurement of the angle of the tilt of the blade's tip toward or away from the gearcase. The angle is measured on a line extending from the center of the hub through the center of one blade. <br /><br /> <br /><br />Propeller Cup <br />Cup is the added curved lip on the trailing edge or blade tip. This added curvature will increase pitch when added to the trailing edge and increase rake when added to the tip. Cupping a propeller will cause a decrease in RPM. The actual amount of RPM decrease is dependent on where, how much, and the quality of the cupping. Cupping also tends to decrease ventilation and allows higher trim angles and transom settings. <br /><br />Dang "This added curvature will increase pitch when added to the trailing edge" NOW WHO CAN WE BELIEVE? THE PROP ENGINEERS
Forktail
Ensign
Have you learned nothing here Backfire? :confused: <br /><br />The difference between "theoretical pitch" and "actual pitch" is slip. Each application or condition the prop is under will result in different slip, or "actual pitch". Theoretical pitch (what is stamped on the prop) will equal actual pitch only under perfect zero slip conditions (impossible). 6-10% slip is common. <br /><br />Again, pitch is merely the distance the prop moves forward in one revolution with zero slip.<br /><br />You can have constant, progressive, regressive, variable and adjustable pitches. It doesn't matter. A 15 pitch prop (whatever way that prop is designed) can only move through the water a maximum of 15" per revolution (under perfect zero slip conditions). <br /><br />You're confusing this "pitch" (inches of forward movement) with "pitch angle" (angle of the pressure face along the pitch line with respect to the plane of rotation measured in degrees).<br /><br />The type of angle of the blade, from hub root to tip, doesn't matter. For example a 2-bladed 15 pitch prop will have a steeper "pitch angle" because it only has two blades to grab water for 15" of movement. A 4-bladed prop will have less "pitch angle" because it has 4 blades to grab water for 15" of movement. Different blade angles, but both still have a 15 pitch.<br /><br />FWIW, the relationship between "pitch" (inches) and "pitch angle" (degrees) is given by: <br /><br />Tan A = pitch / 2P r where A = pitch angle, r = radius, and P = 3.14.<br /><br />
Not sure what you mean by "assigned pitch". Are you talking about pitch angle again? :confused: "Pitch line" is used as a reference for pitch angle, and it is measured as an average along the blade.<br /><br />Regardless, the pitch stamped on the propeller is theoretical pitch, or the distance the prop moves forward in one revolution under perfect, zero slip conditions.<br /> <br />
Commonly accepted formulas (that were derived long ago) have been used by the industry for years. They are standardized. I'll spare their explanation.<br /><br />
Today's prop technology is not new. And yes, there are standardized methods and calculations for measuring propellers. <br /><br />
:confused: I hope not! <br /><br />
You still don't get it. The difference in performance of two different 15 pitch props could be a result of anything. Rake, cup, skew, camber, diameter, number of blades, thickness, material, etc. But all are an attempt to achieve zero slip and a perfect 15 inches per revolution. Different combinations work for different applications.<br /><br />Again (and I feel like I'm repeating myself over and over!), you can not make a 15 pitch prop do any better than 15" of forward movement for each revolution. And it appears by looking at the data posted, that two E-Tech engines are doing this. I say they are exaggerating.
Forktail
Ensign
Backfire, you don't know what the heck you're talking about. :rolleyes: <br /><br />A cupped 15 pitch prop is not anything more than a 15 pitch prop. The cupping merely helps the prop achieve the 15 pitch! It doesn't make it a 16 pitch! <br /> <br />
...with zero slip. <br /><br />There is a huge difference between pitch and pitch angle. The two should not be confused.<br /><br />Pitch angle is the angle of the pressure face along the pitch line with respect to the plane of rotation measured in degrees. Pitch is measured in inches.<br /><br />Pitch angle can better be described per:<br /><br />Tan A = pitch / 2P r where A = pitch angle, r = radius, and P = 3.14.<br /><br />The "pitch angle" is not stamped on your prop. "Pitch" is....the distance the prop travels in one revolution under perfect conditions.<br /><br />
Exactly. Just what I've said all along. The prop will be stamped with "24". Not 22, because it has slippage. Not 26 because it is cupped. 24. <br /> <br />
The affects of cupping are included in the pitch number! That is why a cupped 15 pitch prop looks different than a non-cupped 15 pitch prop. But both are still 15 pitch props! Both will still advance 15" per revolution under perfect conditions!<br /><br />Backfire, I can lead a horse to water, but I can't make him drink.
rodbolt
hello<br /> Forktail<br /> dont be so hard on backfire. the cupped/pitch comment comes from either the seloc or clymer manual. I thought it rather funny the first time I read it. if you really want to blow minds a dissertation on the reverse angle engineering for counter rotating propellers would make a killer thread :) .<br /> anyway I tend to agree that the testing done was overly optimistic but I hope not. I am tired of seeing the consumer get pooched year after year while doing the manufacture's water reliability testing. and the 2 qt a year oil usage was so funny I am still ha ha'ing. if that is what they base the engine durability on then watch out folks, the underestimators are at it again. <br />good luck and keep posting
Fowlplay1
Guys, I have really enjoyed reading your post on the E-tec. I am the one who started this thread when I was looking for a motor for my new War Eagle. <br /><br />I did go with the Evinrude E-tec and will pick it up from the dealer early next week. I will keep in touch on the web site and let you know how the engine is preforming. <br /><br />This was by far the hardest purchase I have ever made. I looked around, talked to others, and posted several threads at web sites like this to learn the most I could about outboards. I feel I have made a good decision but only time will tell.<br /><br />I would like to thank every one who has posted on this thread, I have enjoyed comming home every day to read your input and have even got a few laugh's from the back in forth bickering. <br /><br />Good hunting and fishing<br /><br />Mark
seahorse5
Congratulations on your purchase. You have a whole newsgroup waiting to hear about your experience with it.<br /><br />Here is some info that you might find interesting.<br /><br />EVINRUDE E-TEC ON THE YUKON<br />Recently, Craig Campeau of Campeau’s, an<br />Evinrude® and Johnson dealer located in<br />Fairbanks, Alaska, worked with local resident,<br />Tommy Kriska, to carry out what ended up being<br />a unique test on a new 50 hp Evinrude E-TEC™<br />outboard engine.<br />Tommy put the engine through some rigorous<br />tests: morning start temperatures as low as 8° F<br />(-13° C) and mileage of 350+ per day. The<br />engine performed superbly, but more importantly<br />it helped Tommy carry out his daily work on the<br />river without any hitches. He finished the testing<br />only when the Yukon froze over.
jegervais
seahorse,<br /><br />I can't wait to see Forktail shoot holes in this story...
Fowlplay1
Thanks John, I talked to them and a company in Lake Taho that had been testing the engines all summer. Both of the people I had talked to had nothing but good things to say about the engines and that they were having problems at all.<br /><br /> I feel like Bomb has done alolt more testing on this engine than most manufactures would have before they put the product on the market.
kenneths
Quit pickin' on forktail......he's smarter than you think........ :D
backdraft
The boat used came from a local dealer here in Reno. They have been running the ETec's at Tahoe for a few months. I'll see if my friends at the dealer will tell me anything now. Before they were mum on the subject. nevjb
Tracy Coleman
This has been too much fun to end anytime soon.<br />Fowlplay1 you keep those posts coming, I hope the facts don't confuse too many of us. You will be required to report speed in the form of GPS figures only and of course you will have a tach and an hour meter, right? Any fowl person that would leave the ramp in the dark and or fog nowadays without a GPS ain't got a lick 'o sense.<br />The ducks are tastey up here, good hunting!<br />Backfire ;)
Forktail
Ensign
My only comment would be to those folks who think the "Yukon story" is something special. Many outboards run under these conditions on the Yukon. From vintage 2-strokes to EFI 4-strokes. It's a way of life. So I would hope the E-Tech could do the same. It is a step in the right direction, but nothing to brag about.<br /><br />I'm not here to shoot holes in stories, or bash the E-Tech...<br /><br />Look, if someone says the E-Tech is superior, then I'm going to find out why and how. Because if it can be proven to me that it is superior, I will run them.<br /><br />If someone posts data, claiming it is remarkable compared to other outboards, I'm gonna take a hard look at it. If it doesn't jive, I'm going to show why.<br /><br />If people are pushing the E-Tech as the best thing since sliced bread, then they better have some proof that it is.<br /><br />And if someone posts misinformation about gearing and propping I'm going to clear it up so someone else, who might not recognize the error, gets correct information.<br /><br />I don't know everything, and I'm not always right. In fact I even screw up from time to time. But if you think I'm wrong, you better be able to show me how. ;) <br /><br />All the testing, stories, data, comparisons, and the like won't convince me to buy one....Not until it can be verified with some consumer history. Totally new technology from a totally new outboard manufacturer....I'll wait, thank you.<br /><br />Again, I love Bombardier products and I hope the E-Tech works out. It appears many of you have mistaken the point of my posts.
Fowlplay1
I did get a Lowrance LMS320 with GPS, and also have the tach and hour meter. I will be happy to post some figures for you guys.<br /><br /> I have a hell of alot less experience than most of you on here, and I am not trying to prove anyone wrong. I have no idea how this thing will run when I get it but I am excited to find out.<br /><br /> <br /><br />Fowlplay1
bo2
Wow! Took me an hour to sort this one out. Does it all really matter in the broader sense? As long as you can get out and get back in safety. That John from Illinois....hmmmm...seems to run off at the key board pretty good. Wonder if he can catch fish. I'm surprised that the Yamaha supporters aren't here big time. I'll see what I can do.
