evinrude electrical question?
gtownky
I purchased a pontoon boat that i am currently rebuilding. I have 1973, 85 hp motor and i purchased a console that has Binnacle mount remote control already mounted to the console. It appears to be brand new and real nice control. I have been told that the BRM control is wired for a newer evinrude motor. I was thinking that there should be a adaptor available for the newer conections to the older motor and have called 1 place and told that one was available for a couple hundred dollars. Im not spending that kind of money for one and was woundering if someone knows the wiring diagram for either unit so i can cut the ends off and join the two or does someone have a better idea? Thanks
tashasdaddy
Re: evinrude electrical question?
it is possible, but i do not have the info you need. i just helped a guy in your situation. we removed the new harness and installed a used OMC Red Plug harness. the ignition switch fits right into the BRM, and we strapped the horn with zip ties.
