Lakester
Thread starter- Joined
- Nov 17, 2007
- 428
hello,
i would find it very helpful to be able to read a list of the sealants considered essential for working on evinrudes and johnsons and other outboard motors by name. in my oem evinrude service manual they list 5 or 6 lubricants; everything from oil can to grease gun. in one iboats post on this subject reference was made to a sealant i assume is a waterproof semi-liquid paste type. another referred to water-proof grease.
many of u r active outboard mechanics running or working in marine shops. by name and application what do you use?
i can refer to gasket sealer as paste type that comes in a tube. or i can refer to it as a thread locker. but it is more clear as to what to get if i say, for example:
Permatex non hardening sealer (tube) type C; use-most fiber gaskets, pan, water pump, etc. or
Permatex hadening sealer (tube) type B; use on intake manifolds, valley pans. pan to main cap seals, or
Permatex RTV red (tube) Hi-Heat. Gold tube, for exhaust, intakes, valley pans, or
Permatex Aviation Gasket Sealer (tub/brush) for most fiber gaskets, pan, bolt threads into water jackets, heads and water pump, etc.
if i went to my local evinrude/johnson dealer and looked at sealer/lube supplies out on the floor to work on my engine with, i would not know what is the best to consider. i went to a marine store other day and they had several types of greases. some said water resistant, others said highly water resistant, non said waterproof. and one designated for marine use, a moly type, said nothing about being water resistant or not.
i would like to know the brand, model and type used most frequently in the marine engine trade for such areas as:
water pump/impeller unit parts
lower case to exhaust case
new seals both into metal case and seal to shaft
water thermostat items/gaskets
head gaskets if any
head water passage gasket
crankcase pans
bypass covers
grease for zerk fittings on outboard
any brand of dielectric grease preferred?
lower unit drain washers. if oil, oil, if other please state
spark plug thread-anti seize?
cable lubrication
steering arms
is mount tilt (manual) greased or oiled?
etc, etc.
perhaps this could become a permenant area of iboats tech that others could add to?
i can use Permatex Aviation Gasket Sealer to 'waterproof' and seal... head bolt threads into blocks exposed to water and high heat, i can use it for water pump, thermostat applications, too. no doubt it is quite 'waterproof'! so is it good to use on marine applications, too? i am confused as to what is best to use for gasket and sealant work on an outboard motor and its parts.
thanks...
regards
lakester
head gaskets if any
crankcase pans
bypass covers
cable lubrication
steering arms
etc, etc.
thanks...
regards
lakester
