Re: Evinrude Fastwin
when you get there look at the gas connection. if it just gas the gas inlet, and the clip pin, it is a single line. if it has the gas inlet and air inlet, plus the clip pin then of need the old pressurized tank with two lines. if it is the one line get a metal tank and a evinrude/johnson hose. i've had a lot of trouble with the plastic tanks, and after maarket hoses, like walmart sells. if you need a pressure tanks there are some still around.
