evinrude ficht 150 2000 model
mikemcc
hi
i wonder if you can help bought a secondhand boat with a 150 hp evinrude 2000 model boat ran good allday until i got to the boat ramp when the enjinlight came on and it died will not start again i cleand feul line out (lots of water in feul filter motor backfires sometimes when i try to start it
hope someone can help
jojo999
Re: mikemcc
Re: mikemcc
You can try putting some fuel desiccant into the tank and running through the systems a bit. Also, make sure to change the fuel filter and get some clean fuel into the system ASAP.
.G
Argo Boat
mikemcc
Re: mikemcc
Re: mikemcc
it is a ficht fuel injection does the sensor on the plastic flywheel cover have anything to do with ignition timing
mikemcc
evinrude ficht 150
evinrude ficht 150
can anyone tell me if a 1997 v6 evinrude ficht ecu will fit a 2000 model v6 evinrude ficht
mikemcc
Re: evinrude ficht 150 2000 model
i have replaced all filters and cleand feul system did not work took the boat to the dealers they said the cranck sensor is faulty and it may be the ecu as well because of low voltage on the coils a new ecu is 4500 dollars found this one on e bay fot $1000
