Britcheflee
- Joined
- Oct 4, 2010
- 79
A word of thanks to those who gave advice information regarding the 6hp Evinrude fisherman I was working on. I eventually got a new impeller from NAPA and just cleaned up all the other parts really well. I bought a new 1 inch roll pin for the top of the drive shaft and cut it down to 3/4 inch - I got new bolts for the lower unit and for the water pump housing - the water pump went back together easy - getting the lower unit back up into place and getting that nut back on the clamp was a bear - took me ages but evenually managed to wriggle it all back together. Fired it up on the small boat I have on the pond - nice flow of water from upper exhaust and ran nice - a little smokey at lower rpm - maybe have the oil mix a bit rich. I took the cover off the thermostat housing and found the thermostat really corroded in there - took it out and soaked it in clr and cleaned it really well with wire brush - tested in hot water and it worked. Put back together and seems fine.
NOW - I hauled my other project out of the barn - it is a 7.5 hp Fleetwin - in really nice shape. I want to replace the impeller for this as well - of course I got the lower unit down a way but could not see how it could come off - now I see I have to remove the power head - are the bolts which hold this on fairly obvious? I want to check the thermostat on this one too in case it is suffering from the same problem - only thing is that i do not see an obvious location for this on this model - does it actually have one? is it under that cover on the side of the engine?
Thank you,
Lee
Thank you,
Lee
