Britcheflee
Thread starter- Joined
- Oct 4, 2010
- 79
Well, got all my parts and put the fleetwin back together - I have a nifty running location for it....at the end of the small pier in our pond I put a cross member and the engine sits on it with tank sitting on deck - fired it up and lots of water coming out of the exhaust port area - so that all worked good.
The engine starts great and idles fine I have high speed issues - can gradually increase rpm up to about 3/4 throttle where it starts to misfire then beyond that will either run no faster or die depending on where I have the high speed adjustster knob - I know it should run faster than it is as well. I can get higher rpm in neutral but in gear will not go to full rpm (to my ear only) - any suggestions? Could the high speed jet be clogged in there? Can I remove the needle completely from the high speed adjustment to spray carb cleaner in there? Any suggestions as to other causes for this?
BTW I put the fuel oil mix just like it said inside the cowl - 1/2 pint oil to each gallon....sure seemed a lot to pour a pint into two gallons of fuel but it runs great on it.
Also, I do not have a handbook for this motor - any info on adjustment of the slow/high speed knobs would be much appreciated.
Thank you
Lee
Thank you
Lee
