duckland23
Thread starter- Joined
- Apr 23, 2012
- 175
My evinrudefleetwin 7.5 hp 1957 wont stay running for long or will it idle down in slow speed if I turn the tiller handle, just fast speed and sometimes not much . . Im unsure if the low speed jets or passages are pluged up . Should I rebuild it and clean the carb , I have the kit for it from napa auto parts . I know there's a filter bowl under the carb and its full or can it be the pressure tank not working right .
I did'nt change the points and condenser on this motor or did i rebuild the carb on it at all Ijusted looked at them , they looked ok .. I have the kit for it and am thinking of taking it apart for cleaning today . I need to get some cem dip in the gallon can to soak it over night . i did not buy the carb kit with the float napa for some reason did not have it for this motor . I had this motor running about a week ago .
Also should I change the o=rings on the fuel conector off the fuel tank . I heard they leak air from bad o-rings . if so what size are those o-rings in it . My auto parts store will have o-rings for it . How would I get it apart . I seen a guy use a punch to remove the square metal block in it along with the spring . Im going to start with rebuilding the carb first and then the o-rings in the fuel conector . The fuel line is ok and I think the tank is holding air . But i seen some bubbles at one of the screws . Should I tighen it up . or rebuild the tank with a new kit . were would you start at .
