banana man
Thread starter- Joined
- Apr 6, 2009
- 8
Yes I stripped the slot on the screw and now it won,t come off.. can I drill a small hole in the middle of the screw and than use an ezout to remove it??
Can you cut into the slot deeper...or square it off and use a bigger screwdriver?
MAS
Second on the Impact wrench. Works better if the lower unit is removed and put on the bench, so you're banging down instead of sideways.
Use an EZ out at your own risk. More than likely it will just break off, then you'll be shopping for a new lower end.
LOL, Ok I,m back, Anybody no a web site that will sell me the evinrude oil drain screw cheap??
