evinrude lower unit
cowherd
Re: evinrude lower unit
I am new here don't know how to post pics the problem with my lower unit is oil leaking from between prop and unit is that a easy fix?
boobie
If the oil that is leaking is black and smells like fuel it's from the motor.
Faztbullet
Will a lower unit from a 86 evinrude 200 fit on a 85 evinrude 140
No... they look the same but gear ratio is different
cowherd
Thanks for the replies just bought this boat for the motor for the starcraft that I am restoring this motor has not been started in a few years. I put a battery in it and some fuel and it fired right up sounded good idled good and when I shut it down I noticed the oil coming out from between the prop and unit. Haven't had time to check out cause of the rain and work.
