evinrude motor specs
thmlrmg
Re: evinrude motor specs
if you post you year make and model someone could look it up for you.
skidog12
evinrude 60hp sportfour<br />model# 60653r<br />boat is a 1966 glasspar 15ft runabout
JB
Howdy, Skidog.<br /><br />I don't have a chart on 'Rudes, but I do know that the Johnson 60hp V4s were made in 1964, and the fuel mix recommended was 24:1.<br /><br />Hope that helps. :)
skidog12
hey thanx guys , i just got off the phone with a dealer and it seems that with fuels today they are recommending 50:1 ,but i appreciate all help and responses
JB
Not a good idea, SkiDog.<br /><br />Today's fuels are worse, not better than yesterday's fuels. Today's oils are much better, but your engine still has sleeve bearings and still needs a richer mix.<br /><br />I am amazed that a dealer would tell you that! :eek:
skidog12
hey jb what you reccommend to mix this 1966 60hp evinrude at ?
JB
Hi, SkiDog.<br /><br />My book doesn't cover '66, but I suspect that 24:1 was still the mix recommended. I could be wrong. If I am wrong a 24:1 mix will do no harm, but if I am right a 50:1 mix might kill your engine.<br /><br />Someone should come along who has the book on the '66.<br /><br />Good luck. :)
seahorse5
OMC changed to 50:1 back in 1964. Your 60hp, no matter which year, does not have sleeve bearings, it is all roller and needle brgs. You can use 50:1 with no problem since that is what is was designed for.
