evinrude motor....will it work with merc steering cable?
Larry Tate
hey guys i have a 1979 evinrude 115 hp and the boat i am putting it on has a steering cable installed already but it was for a mercury. it looks the same, its the type that goes thru the front of the transom bracket. will the threads line up on the nut/motor bracket, and will it be the correct length from the nut? thanks
mark1961
Ensign
Re: evinrude motor....will it work with merc steering cable?
The cable should work on both.....the link (connecting rod) from the end of the cable to the steering arm might be another matter though.
1946Zephyr
Yea, it's worth checkin out.
boobie
You'll most likely need another steering link from the end of the cable to the mtr. Other wise it should work.
Larry Tate
thanks for the info...if the rod does need to be replaced, are they easy to find/ hard to replace?
boobie
Easy to replace. There are different steering links for different model mtrs Check with your BRP dealer.
Larry Tate
thanks a lot
the machinist
What are you planning to use for controls? One old boat & OMC motor I bought had Merc & shift. The Mercs shift was backwards as compared to the OMC
