Evinrude Mystery Model no 115093D
Storskar
I have an Evinrude 115 Hp outboard. I have been trying to find out what year it was made but can't find the number in any of the published tables. <br /><br />Any experts out there that can advise me so that i can get the rightservice manuals etc?<br /><br />/Micael
Joe Reeves
Re: Evinrude Mystery Model no 115093D
There is a model number 115083 and a 115393 but there is no such number as 115093 listed.<br /><br />On top of the port side of the powerhead, there should be a core plug (Looks like a small freeze out plug). What numbers do you see there?<br /><br />Describe the engine ignition system, how many powerpacks, exactly where are they located, where is the engine electrical terminal strip?<br /><br />If you have a digital camera, send a few pics of the powerhead etc. ReevesJ32@aol.com
Storskar
Hi Joe,<br /><br />I will try to take a pic when i get home. Meanwhile: V4, two-stroke, electric push-button gearshift, no power trim, white GRP hood, grey brown lower part.<br /><br />Power pack, i am not sure what that is but there is an electronic "ignition box" (3" x 4") w cooling fins located in the V, that is between the left and right row of cylinders as seen from behind the boat. The electric termination stip is located above the "power pack" also in the V, covered by a black bakelite lid. Between those two there is a smaller squarish (2"x2.5") aluminum box. The starter is located on the left side of the engine looking at the engine from behind the boat.
heyitswebb
I have a 1972 100hp starflite evinrude. It sounds like you are describing it perfectly. you should be able to get the serial number off of it somewhere. it will be a #-##### the first 2 #'s after the dash will be the year model reversed.<br />example 0-27678. this means that it is a 1972 modelthe nubers you posted is the model number and it has the horsepower as the first 3 numbers. example #100293r means it is a hundred horsepower motor. Hope this helps. I also post a link that was given to me on a 1971 evinrude brochure, the pictures might help. Tim
Storskar
Hi Heyitswebb,<br /><br />Sorry, i can't get the link to work, page not found...?<br /><br />/Micael
Joe Reeves
Storskar.... No need for the pictures. You have just described a 1970 115hp Evinrude that has Battery Capacitance Discharge ignition and a Hydro Electric Shift system.<br /><br />The colors mean nothing as "white" would indicate a Johnson engine, and "gray/brown" would indicate only God knows what.<br /><br />The description of the powerpack w/cooling fins might indicate that the powerpack is original equipment.<br /><br />Stare at the "115093" long enough and you might see a "8" replacing that "9". The only other explanation I could think of is that something goofed at the factory or someone has installed a fictitious ID plate.
heyitswebb
your right that address do not work. Go to a post I put on about a week or so ago on page 6 or 7 it is titled" I need help" there you will see that link to view the 71 evinrude motors. It should help you identifiy yours. tim
heyitswebb
you can check my post it is here on thepage look for heyitswebb, that link will be there. Tim
Storskar
Many thanks to you Joe Reeves and Heyitswebb for taking the time to help me identify my engine.<br />You seem to know what you are talking about!<br /><br />My reason for needing the year was so that i could order a service manual (any you can recommend?) to try to rectify my problems with the machine. <br /><br />1)<br />Everything is fine at low revs and idle but as i throttle up the engine "studders" and refuse to rev up. Spark plugs wet and black. <br /><br />2)<br />Absolutely guzzles petrol!!! 55 litres gone in a whiff!<br /><br />3) <br />What oil mixture (1:50?) and octane (98 unleaded)
Joe Reeves
Storskar.... Assuming that the compression and ignition (spark) are okay, the answers to your questions:<br /><br />(You)"Everything is fine at low revs and idle but as i throttle up the engine "studders" and refuse to rev up. Spark plugs wet and black." <br /><br />(Me) Sticking timer base under the flywheel or fouled carbs. Carbs may simply be out of adjustment. Try adjustments first (listed below).<br /><br />(You)"Absolutely guzzles petrol!!! 55 litres gone in a whiff!"<br /><br />(Me) Same answer as above.<br /><br />(You)"What oil mixture (1:50?) and octane (98 unleaded)"<br /><br />(Me) Use the 50/1 mixture with 87 octane unleaded.<br /><br />Now, to adjust those carbs.....<br /><br />(Dual Carb V/4 With 4 (2 each carb) Slow Speed Adjustable N/Valves)<br /><br />The adjustment procedure of the carburetor slow speed needle valves follows. NOTE... if the needle valves turn too freely, replace the nylon bearing retainer (the nylon item at the front of the carb that the needle valve goes through first) with the newer type RED retainer #315232. If your engine has that weird linkage that connects all four of those needle valves, the newer RED retainers will enable you to discard that linkage. The RED retainers make it impossible for the needle valves to viberate out of adjustment. <br /><br />(Carburetor Adjustment - 2 Slow Speed Adjustable Needle Valves, each carburetor) <br /><br />Initial setting is: All (4) Slow speed valves = seat gently, then open 1-1/2 turns. <br /><br />Facing the carburetors, start with the top left needle valve, then the top right valve, then the bottom let valve, then the bottom right valve. It may be necessary to redo these steps to get the adjustments ideally set <br /><br />Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. <br /><br />Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />Do not attempt to gradually adjust all four of the valves at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve. <br /><br />When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Storskar
Thanks Joe!!!<br /><br />I will do the carburetor setting this weekend!<br /><br />You say "Assuming that compression and spark is ok" <br /><br />Compression: I checked that but i don't know what reading the compression should give, i just noted that they were quite level to eachother.<br /><br />Spark: I have spark at low speed at least on all four but at higher speed it seems to cut in and out...studder as if a wire was loose or it was running on the last drops of fuel. But i guess that black and wet plugs have a hard time doing their job<br /><br />Br/Micael
jimchere
Storskar, I noticed you are in Sweden. One more thing to add about the gasoline when talking with people in the US is a different octane formula is used. In the US, the "RON+MON/2" method is used, vice in Europe where only the RON is reported. This makes your octane numbers over there seem higher when in fact its just a different formula scheme. As Joe said above, 87 US octane is fine (by the R+M/2 method). That equates to roughly 92 octane in Europe (by the RON only method). Your 98 octane (RON) is equivalent to our 92 (R+M/2) in the US.
Storskar
Wow! <br /><br />The level of knowledge in this forum is really impressive! <br /><br />You are right, i think that I only have 95 & 98 unleaded to choose from, and i have absolutely never heard of 87 octane. But from what you say 95 should be ok?<br /><br />/Micael
Spidybot
Right about the gas. You can't get a too low octane rating in Sweden. Running 98 is a waste of money - just stick with the standard 'Blyfri 92'.<br /><br />In Sweden the green line (Grön) has a 5% addition of ethanol... not wanted in outboard fuel.
