evinrude outboard
ringo111
guys i just done a compression test on 140 hp and all 4cyc are reading 90 psi motor is a90s model ,can this be possible that all 4 cyc are reading 90 psi .i even doubled checked with 2 testers,fm what i been told usually 1 or 2 cyc will read in 100 psi range like to read your comments.
JB
Re: evinrude outboard
Your compression is fine, Ringo. When all cylinders match you can't get any better.
ringo111
thanks jb i was getting worried .thinking motor was on its way out.thanks again
5150abf
I have read that the 90s do run a bit lower compression so 90psi on them is really good and I agree with JB, you can't get any better than that.
Faztbullet
It a looper and that about perfect on them, if it was a crossflow I would say its low.
