Evinrude prop assembly part ID needed
jimp37
Hello, I removed my prop to clean and grease the shaft and after removing the thrust bushing {part# 0334590** there sat a severely worn very thin plastic o-ring of some sort. Sat directly behind the thrust bushing. Would anyone know if this sits inside the groove in the actual thrust bushing, or is there a separate part that is in fact supposed to sit directly behind the bushing? Was more like 3/4 of an o-ring it was so deteriorated. 1994 Evinrude 9.9 E10ELERB. Looked in the schematics but did not see anything similar.
jimp37
Thinking now maybe this is just a sliver of the seal that shaved off over time { part 0321481} ??
