Evinrude Rectifier Problems
John Varr
Re: Evinrude Rectifier Problems
I never switch batteries with the motor running. But if the switch was going bad, I can see how it would damage the rectifier. I could try replacing it or opening it up to look at the cotacts.
seahorse5
Originally posted by ScubaDog:<br /> I've got a 97 Evinrude 90 that has blown several rectifiers.
the 25" version of your motor uses a watercooled rectifier/regulator charging system, part number 585195. It would be a vast improvement to your system if you installed it and removed the rectifier assembly.
John Varr
Seahorse,<br /><br />That sounds good to me. Do you know if it will fit my motor without a complicated conversion or changing the stator?<br /><br />Dog
Dhadley
Its a direct fit. You can actually use the crossflow 35 amp reg/rec if you wish.
Bushleaguer
I switched to the water cooled rectifier/regulator two seasons when I had an overcharging problem that burned up two tachs and cooked two sets of batteries. I have had no problems since and only run one battery at a time. (Evinrude 115 spl) It was an easy install as well. Good luck.
