Charles King
Thread starter- Joined
- Nov 23, 2009
- 37
My 1970 model 70873c will run at wot, then when slowing to run in no wake zone, or approaching dock. After wot, it dies. It takes approx a minute at the shortest time. Idles and wot on muffs in or out of gear. I know, this is a no load situation.
I am a non believer in parts changing to cure a problem. Plugs look good. Since it runs very smooth at idle on muffs, i checked the fuel pump.
The diaphram is very stretched. If this is like small engines, this may be my problem. I am going to try continually pumping the primer bulb.
Is this a good test for poor fuel pump performance, if engine does not stall.
As i said, i am not a parts changer or carb rebuild fan. Too many years running dirty engines.
Carbs were rebuilt last year.
