Ron Whitnwy
Thread starter- Joined
- Aug 16, 2001
- 8
I have a '78 model 115 hp Evinrude that I just got. It has sat for about three years. With a little work I now have it running great. however, When I use the tilt and trim it will raise but will not lower. After you raise the motor then try to lower it you can hear the motor or whatever supposed to lower it run but nothing happens. I would appreciate any help and advice. JB put a reply on my question in the boating forum suggesting that I may be low on fluid. It is the type of trim unit that the cylinders are under the motor when it is up. JB suggested that I fill it up cycle it a few times let it sit an hour and fill again. There are two cylinders which one do I fill and how will I go about raising and lowering the motor to cycle it when it will not go down? I know there should be a manual lever or something but I am not sure what I am looking for. I do see a plastic lever on the left side of the motor but nothing happens when I work it.<br />Thanks for the help,<br />Ron
