evinrude tilt/trim
levi501
90hp 88'evinrude tilt trim not doing anything but power is going to motor and fluid topped off. i am trying to replace motor but i dont know how to get the 3rd forward portside screw.
OBJ
Re: evinrude tilt/trim
Welcome to iboats Levi!
What you will have to do is disconnect the tilt ram, take a couple bolts out that hold the unit between the transom brackets and roll the unit out to get to the motor. A servie manual, OEM, would explain how to do this.
Well, I just tried to get on the BRP parts catalog page but it's outta' service for now. I was going to post you the addy so you could at least see the parts breakdown.
Essentially, there are three bolts on each side holding the TNT unit in place. Remove the top two and losen the bottom two, take the tilt cylinder ram pin out and the unit should fall forward enough so you can get to that elusive third screw. Not really a bad job....but you will have to support the engine so you can take the ram pin out. I check the BRP site again and post the link when I can.
rickdb1boat
You will probably have to retract the ram some to get the unit to lean out. Here's a pic of mine, which should be the same as yours...
OBJ
Dang Rick!! Wish I new how to post those pics like you do. Makes things so much eazier.
OBJ
I'm already using Photobucket to post pics, didn't know you could do that there. Have to take a look. Thanks Rick!8)
Johnson110
Just wanted to add that I did mine, but took the whole bracket off ( side with tilt motor) gave access to the motor trim bolts!
OBJ
Can't remember the years right off, but in some later years, you didn't have to losen the transom bracket to let the TNT unit roll out. Some earlier years you had to.
rickdb1boat
Yep, when I take the bolts and ram loose on mine, it just rolls out. This is on a 91' model 70 HP...
