Evinrude trim/tilt problem
Hamish24
Hi. I have a 85 evinrude approx 1976 model. The trim/tilt works fine on trailer and when idling around but when on the plane cruising or towing and you want to trim motor up a but it just won't move. Would this just be the pump bring tired? Any easy fix?
emdsapmgr
Re: Evinrude trim/tilt problem
Did you check to be sure the trim oil reservoir is full of trim fluid?
Hamish24
Hi. Well I have checked the main plug on the side of the pink yes. There is a flat head screw a 1/3 way up from bottom that even when motor is all the way up oil still comes out if it. It is a bad colour and needs changing. Is there another place to check that is different than this?
emdsapmgr
That plug on the side of the reservoir is the place to check the oil level. If the fluid is not pink and clear, it may be diluted with water. That could be why it may seem overfull. (the oil should be full to the bottom of the fill hole.) You can try to evacuate the system (drain it) then try to refill it with new oil, then see what happens. You would need to open up some of the high pressure lines in order to fully drain it. It may start working again. I'd recheck it periodically, as the oil may get contaminated again, indicating a seal leak in the system. At that point, you'd need to start looking for source of the leak.
Hamish24
Hi thanks there are 2 screws for checking level. One near bottom as described abs one near top in middle? Which one should i check the level with? Also what us ur email? Would like to send u a pic of the pump to see if there are parts available or not
emdsapmgr
You can view the factory exploded parts list for your exact model. Check out this website: epc.brp.com. The trim system is shown on the 85 hp parts diagram. The fill plug is item 76 on the diagram. I don't see a similar plug for the Prestolite version. Maybe someone else has better eyes....
