evinrude V-4 ID and prop info
ccpanel
how can i find the true year of my boat and motor?<br />how can i find a new prop for my boat or find out what prop will up my speed.<br />mark<br />evinrude@customclassics.org
ob
Re: evinrude V-4 ID and prop info
Well,You could start by posting the make and model number of each.Next ....to select a prop that will be compatible with your engine and boat,you'll need to know the manufactures recommended wide open throttle operating range and prop the engine accordingly.<br /><br />Once you post what engine make ,horsepower ,and model number you have,someone can assist you with prop selection ,based on the boat that is being pushed and knowing what rpms at WOT you are currently running with what propeller.Good luck.
ccpanel
my boat is a 65? evinrude 16' trihull with v-4 that the nameplate on the boat by the driver says <br />88hp<br />m-214502a<br />s-w-1-14898<br />its got the power head inside the boat with the drive and turning parts outside the boat.<br />2 cycle.
ob
Check out this site and see if you can find something close to your number.Scroll about halfway down the page.<br /> web page
