evinrude v4 90hp 2 scored cylinders
emmo1210
Hi guys,
Just stripped my engine down and found that the 2 bottom cylinders (as the engines sits) were quite badly scored but the 2 top ones were fine.
Im guessing that this rules out the VRO pump? is it likely to be the bottom carb at fault or am i way off the mark?
Thanks for any help
emmo1210
Faztbullet
Re: evinrude v4 90hp 2 scored cylinders
Your on the right track!!! Check for debris in the high speed jets or under inlet needle that restrict fuel flow.
HybridMX6
Agreed. INspect that lower carb very well. Clean/rebuild both carbs anyways, just be sure to check that bottom one especially well.
emmo1210
Much appreciated guys,
ill take an inspection of the carb and post back my findings.
