Evinrude Water pump kit
carbineone
Can someone tell me the part number for a 1974 Evinrude Lark Model number 50472? Thanks
carbineone
Re: Evinrude Water pump kit
Found the number so disregard that part.I am maybe going to replace this as it seems a little weak pumping water at idle but pumps good when at a higher rpm.Is it normal for them to be a little weaker at idle or should I just replace it to be sure?The top head seems to run a little warm at idle but runs cool with the RPMs up more...Thanks
carbineone
Thanks again Tashasdaddy and yes I found the numbers for the kit here but does what I am describing it is doing sound normal or should I replace it and if so just the impeller or the whole works.They do not list a kit with the housing included just the two seals,the wear plate and the 4 new bolts and the impeller.Do I need to find the new housing too?I really do not want to replace anything if it is not bad...
carbineone
I do not know if you will see these pics real good but I will try.As you can see just above idle it sparys water out the 6 holes on each side above te cavitation plate and in the one shot you can see a pee hole way to the front where water comes out too.The water is warm coming out the sides too. Anyway thought a couple pics might help...Thanks
