saxmanbrad
Thread starter- Joined
- Jan 15, 2012
- 9
Hey guys I have a 1991 Xp 175 that has the 35 amp charging system....the flywheel has about a 2 inch section of sheared teeth on the ring gear. The compression of the motor likes to leave the flywheel in this spot after the motor is turned off, hence the starter just spins and can't engage the ring gear. It's annoying and slightly embarrassing to have to pull the cover and turn the flywheel by hand sometimes. Here's my question, used flywheels for this motor seem rare, is it possible to just replace the ring gear. Or...is it even feasible to have someone weld some metal onto the stripped spot and re cut the teeth on the ring gear? Any thoughts would be appreciated. Thanks!
