MASTER Brian
Thread starter- Joined
- Mar 26, 2006
- 738
Re: Evinrude XP150 not accelerating
Ok, I have a manual and sitting here at the office, I'm looking through it. It says, "A (fuel)pump that is operating satisfactorily will deliver a good, constant flow of fuel from the line. If the amount of flow varies from pulse to pulse, the fuel pump is probably failing."<br /><br />When I checked the pump before, the fuel came out in spurts when I cranked over the engine, are they saying it should be a solid flow? <br /><br />I realize that since the compression on this cylinder is low, that might cause incorrect fuel delivery, but I want to know what to expect. As that would sort of make sense why it isn't running right. Granted I need to get that compression up and the head should be coming off tonight, just want to know what I'm looking for in the larger picture.
