Excellent Decal removal tool ...WOW
crazy charlie
Changing out the decals on my Yamaha 200hp.Found this and it kicked A** on removing the old decals.Rubber eraser wheel on drill made quick work of removing all old decals.Maybe 15-20 mins topshttps://www.zoro.com/3m-stripe-off-wheel-4-dia-x-58-t-x-38-16-07498/i/G1358585/feature-product?gclid=Cj0KCQjwt_nmBRD0ARIsAJYs6o3yTlItBVfAeSzap1Vyi3QhSzJlmesC_x1s1YDSLhV8jT-xZzfndDQaAgWvEALw_wcB
Lowlysubaruguy
Heat gun and a plastic spatula or bondo spreader then rapid remover for what ever adhesive is still stuck to it less chance of burying the paint with a rotating device.
H20Rat
Used 3m wheels for a long, long time! They work well, and unless you really try hard, they won't burn paint or fiberglass. Just follow up with goo-gone or wd40 to remove any left over adhesive.
ahicks
Yup, a fan of the eraser wheel here too. There is a knack to using it well. You get pretty good about the time you're finished....
Bob_VT
Yes, NAPA sells a wheel and also I have found Plastic Razor Blades are really a fun tool too that will not scratch.
