Re: Excess carbon-heavy oil from V-6 200
Final Post
The problems surrounding the original failure of the "replacement" piston have been corrected...to a point where the motor runs very strong and is "good to go".....
....except for a small little problem.....
I have determined that the source of the trace amounts of water entering the #2 (top port-side) cylinder is probably due to a poor seal around the steel sleeve and the original bore....
The sleeve is slightly "lower" than the top edge of the bore (where it meets the fire ring of the head gasket) and I am seeing a very small (but noticeable) gap at two locations around the diameter of the sleeve. The gaps are not exactly inline with the "rust" on the edge of the wall near the exhaust port, but this may not matter as the point of exit for the vaporized moisture would be around that port anyway.
Soooo...I am at a crossroads...
Do I pull the Poppet Valve and run a second teltale to reduce the water pressure to "safe-but-low" and just check that bore periodically for continuing scoring?
Or do I send the block out for another sleeve-job and pray the block is still good?
Or....do I cut the block a bit to bring the sleeve top flush with the bore it is in and to the head...so the gasket can seal better?.....
I am thinking that I might do the first and the last steps....unless anyone knows a slick way to pull the sleeve?
I have worked on sleeves for car and truck applications...but this is obviously different and I would hate to kill the block. Heating the outside of the bore and cooling the steel sleeve works for installation...but I have not seen a post from anyone who has attempted pulling one....
And yes...save me the posts about "sucking it up" and spending the 500 bucks to get it done right, ok?, please?...times are tight for me...I have ZERO confidence in the two shops that have butchered this motor already, and I have WAY more time than I have money....the thing runs....and it runs "quite well" at anything below about 45mph...but the water intrusion is basically a bomb waiting to go off and I am an ex-EOD guy...so I am compelled to disarm the damn thing instead of just killing it with water. (actually, this is exactly what we do....water jet via a robotic assistant...
