psimon1909
Thread starter- Joined
- Aug 28, 2009
- 11
Has anyone found a creative and safe way to use all the extra space in the engine compartment. My Q5 has alot of unused space next to the engine. I understand anything I do there must be removable since that it the area the mechanic can sit in for service but the rest of the time it's wasted space.
Has anyone added a storage box that can be removed? (For an anchor, tool kit, air pump, etc.) How would you attach something like that so it can be removed? What kind of box?
My other idea was to add an additional fuel tank. Without doing major modifications I was thinking about adding a 10-15 gallon tank and then running a gas line from the new tank which would be mounted higher into the original tank with a valve that would allow fuel to run from one tank to the other when the bottom tank runs low. Of course you would have to fill up in two places but if I can do it my self its a small inconvenience.
I went to the West Marine rigging shop and they refused to assist in either of these modifications.
Any ideas, suggestions?
