Exhaust Again
carolynrose
I know this kind of post has been discussed before but here goes. I'm shopping for new exhaust for my 1988 Bayliner 2556 with an OMC 260.
I posted before about converting to center rise exhaust and everyone pretty much agreed it was a good idea.
So with this in mind I've noticed serveral conversion kits. Some of the kits are EDP coated, is this worth it?
The other question involves the disparity in prices. Coated older Volvo systems are $100-200 lower than Barr or Osco kits for OMC and I see no difference in their appearance. If I have to adapt my Y-pipe from log to center rise why can't other systems (i.e. Mercruiser, Volvo) be used or is there that much difference in the hook ups. I know that OMC log type systems used a different size pipe but I've found that there is a pipe to convert 4" risers to 3 1/2" pipes when using the center rise conversions.
Helpful information please.
carolynrose
Re: Exhaust Again
In a slip, saltwater all the time. Engine is closed freshwater cooled.
Re: Exhaust Again
Ayuh,.... Are the manifolds included or Not,..??
The Biggest difference is where,+ if there's the accessory mounting holes... Volvo is not Merc is not OMC....
carolynrose
Re: Exhaust Again
Raw water runs through the manifolds and heat exchanger. There are no accessories mounted to the manifolds. That is why I question the difference. A Chevy 350 exhaust port is just that, what is the difference in the manifolds, is it the hose nipples or something I am missing?
The Barr Manifold is listed as a universal manifold for OMC, Merc and Volvo so why don't the manifolds exchange with each, other than some have accessory mounting holes?
Re: Exhaust Again
Donno,... I do know Merc,+ OMC use different riser outlet diameters...
