Randy stoner
- Joined
- Aug 20, 2002
- 78
These things sure are a money pit. I had the outdrive completely rebuilt two years ago and with some bad luck with a new engine and subsequent replacement engine i have about 10 our max on the outdrive. I was told the exhaust bellows was replaced however i noticed today there is a hole in the bottom of it. When storing it through the winter i had the outdrive in the down position and only a week ago did i move it up to start getting it ready for this year. I cant say for sure if it was replaced as the water coming out of it has alwasy seemed to come from that part however Im pondering replacing it.
How big a job is it? Can it be done without removing the outdrive. Does anyone have any hints, suggestion, video or prayers to help me with this. The only OMC dealer around i have had a really bad experience with and in other posts here you would understand why i wont go back. I really dont see an issue with it with the leak as far as running in the water but if it was meant to have one, i would like it the way it should be.
Thanks again, you all have helped me with other issues
Randy
Randy
