May I ask, what is a exhaust boot? How does it work? I might be doing a bellows job this spring, and if the boot is easier, I may just do that.
Ayuh,... When you look up yer Parts, you'll see exhaust Bellows, which attach at both ends,...
And,..
The exhaust Tube, which only attachs to the boat side....
Last week when I was out running up the boat I noticed that the exhaust was bubbling up between the outdrive and transom only??
my mechanic replaced old bellow with new exhaust boot and its seems alot louder and wondering what your experience is with exhaust boot vs bellow.
No, you should be using the boot on the Volvo 270 thru 290 outdrives. The flappers at the exhaust outlet help minimize reversion so you need the boot to direct the exhaust through the outdrive on this design.Are these boots avail for 280 volvos?...or just mercruisers?
