Exhaust by-pass flapper missing
New Era
I have an '89 Bayliner with a OMC 5.0L. The butterfly flapper valve in the right exhaust tube is missing, I think you call it a by-pass valve. I guess it broke off and fell down in farther. If it did is that going to cause a problem, maybe block exhaust flow on that side? Thank You
Don S
Re: Exhaust by-pass flapper missing
It's called a flapper or shutter, not a bypass.
Yes, it can plug up the exhaust. pull the outdrive, you should be able to find it either in the exhaust passages of the drive.
New Era
With the drive tilted up it looks pretty easy to pull off the exhaust boot from the transom. Could I do this to get to the broken flapper instead of pulling off the drive. The reason being is that I have to order every part I need for this thing. I do not live anywhere near a Marine sales or parts store. So if I pull the drive I do not have a new Gasket or nylon lock nuts to replace. I was hoping to get this in the water by Labor Day. Thanks
