OK, finally got engine and outdrive in after spending $600.00. Now I have an exhaust leak right at the end of the 2 y pipes going into the out drive. The boat mechanic says the outdrive and engine have to be removed to check for leaks and possibly tighten the 2 top bolts at the flange, on the center section where the 2 exhaust ducts connect before heading out of the boat. anybody got a better fix than re-removing the engine and outdrive? Thanks
