Exhaust gasket
SweeperForce
Hello,
Well, I am planning to replace both exhaust gaskets. Is there any special order I should remove the bolts? And again to replace them. What is the proper torque for these bolts? Besides PB blaster and tap with a hammer, is there any other infomation I should know about?
Thanks,
Tom
Frank Acampora
Re: Exhaust gasket
First: If you don't have a leak or other problem leave it alone. These are not gaskets you want to replace routinly. And it is WAY easier if the block is off the leg.
At the bottom, at the front of the plate, there is a "dogleg" The gasket is thinnest there and easily kinked. The stainless steel sheet metal plate is usually warped and makes it a bit difficult to assemble.
SO: start with a couple of screws in the center of the plate to hold both gaskets and the stainless plate in position on the aluminum cover. Put against the engine and screw in all bolts finger tight, making sure that the thin spot at the dogleg is not kinked or cut. Use a crossing pattern like when you mount an auto tire. This will shift the assembly so everything is aligned.
Now snug the bolts in a spiral manner working from the center of the plate outward. Finally using the same spiral pattern, torque the bolts to 70 INCH pounds.
Sounds long and complicated but it is really easy and if you do it often it will become second nature. Better to take a couple of extra steps than to need to redo the thing later.
Who is it on the forum that says: "Why is there never enough time to do it correctly but always enough time to do it over?"
The bolts do tend to corrode and cold weld into the casting. If they don't "crack" and start out easily, then use a wiggling motion. If you try to just run these stuck bolts out, they will snap.
It is a given that you will break off at least one. Don't let this discourage you.
If the broken portion is high enough, you can soak it with penetrant for a couple of days, grab with a Vise-Grip and wiggle it out. If you are lucky it will be one that is easy to get to without removing the lower pan.
If the bolt is too low to grab, re-install the cover with as many bolts as you can, then drive a 5/16 roll pin into the hole. Now, using a 3/16 cobalt steel drill bit. drill out the bolt.
SweeperForce
Re: Exhaust gasket
Thanks alot Frank, lots of helpful info. I have a small leak where the ehaust port meets the block. At a rate of a slow trickle. Belive me, this isn't something I want to do. I'll keep you posted.
Tom
pnwboat
Re: Exhaust gasket
It's sometimes hard to get to the bottom bolts on the 150HP motor. If you run into this problem, you can take out the bolts that hold the lower pan to the lower leg. This way you can shift the lower pan over a little bit to get better access to the lower exhaust cover bolts.
SweeperForce
Re: Exhaust gasket
Well, I got lucky thus far. I didn't snap one bolt. I did however, need to loosen the pan to get at the bolts on the very bottom. I hosed them down generously with PB blaster, that stuff is great, used nearly 1/2 the can.
I do have one question, now that all the bolts are out, how in the he## do I get the plates off? Tap it with a hammer, use a screw driver, spray it with some type if solvent? Anyway, I ran out of clear skies amd daylight, so this project will resume and be completed next weekend.
Tom
pnwboat
Re: Exhaust gasket
Try hitting with a rubber mallet? I'd be careful hitting it with a hammer. Could take a wood block and place it against the plate and tap the wood block with a hammer. Look for some spots on the left rounded side of the plate where you can pry gently without actually having to touch the sealing surface. Between the plate and the block. The sealing surface is very narrow. If you jam a screw driver in there and pry, you may cause a problem.
Frank Acampora
Re: Exhaust gasket
The gaskets are factory glued and initial engine heat sets them. They will be destroyed when you remove them. Simply slide a sharp knife inone corner and pry. The gasket will release in some points and tear at others. Most likely you will need to clean the block sealing surface.
You will see, on stock gaskets, a thin line of glue on--perhaps blue-- one side of the new ones.
