spdracr39
- Joined
- Aug 30, 2010
- 1,238
Is there any special trick to replacing the exhaust manifold to cylinder head gaskets on the port side? I can drain the water and remove the hoses. Should I take the riser off also? Do I need to prepare for any suprises? I can hear an exhaust leak on that side near the back two cylinders. Is there anywhere else the leak could be coming from? There is no water only the sound.
