I'm removing the exhaust manifolds for the second time in a few years, and again sheared a bolt. Long story short, engine is a '74 ford 302 on a Mercruiser 888 i/o, used in saltwater and has freshwater cooling. Two years ago, I pulled the engine out of the boat to replace the transom plate and Y-pipes for the exhaust. While the engine was out of the boat, I pulled the exhaust manifolds off the heads, and the heads off the block to fix a few burnt valves. While pulling these, I had one bolt shear flush with the head (one in the rear, where it's the hottest and where it looked like a bit of wet exhaust was leaking out of the risers). I had a machine shop remove the sheared bolt, and helicoll it. The exhaust manifolds / risers are the older "log" style, and at the time looked like they would need to replaced soon. I surface painted them, reassembled and ran these for two summers with no problems.
A few notes on reassembly, I used grade 8 bolts to reattach the manifolds to the heads. I didn't use anti-sieze, and put the exhaust gasket on dry.
Two years have passed, and I picked up some new (used) risers and manifolds to replace the old corroding ones. In pulling everything again, the same bolt sheared in the back. I also noticed that after only two years, the grade 8 bolt heads had some serious rusting... had I waited longer, I'm sure I would have had more problems pulling these bolts.
My questions, should I use stainless instead of grade 8 to bolt the exhaust manifolds to the heads? Should I use anti-sieze?
Thanks in advance!
Thanks in advance!
