I have a 1989 4.3 OMC/V-6 Cobra with 1 piece exhaust manifolds.Those of you that have experienced with these know how hard these are to find and how expensive they are when you do, not to mention they are too heavy and a pain in the butt to deal with. My question is, do I have to use these? If the mercruiser uses the same GM v-6 block, then will the mercruiser manifold bolt up to it? If all I need to do is modify the output side of it to fit my OMC's y-pipe using some stainless tubing and exhaust bellows, then why not use it? I would like to use the aluminum 2 piece exhaust to save weight. If these are too much trouble, does anyone know of any aftermarket exhaust systems that will work without costing more than the boat is worth??
