1980Coronado
Thread starter- Joined
- Oct 8, 2010
- 699
Last night I winterized my 1980 Coronado and when I drained the goose neck/riser on the starboard side, quite a bit of metal flakes ran out. I've winterized I/O's before, and have seen stuff come out before, but not in this quantity. I used a wire to poke in the hole as the water came out and was surprised by the amount of junk that came out. Didn't get much of anything out of the port side except the water. This is only my second season with this boat and all indications are that these are original manifolds and risers. Last year when I winterized, I had to drill out the 1/8" NPT holes and go to 1/4" plugs because the threads were so rusted/rotted out that the 1/8" plugs wouldn't thread in anymore. I drilled both manifolds, but could only do the starboard riser. The port riser is the same part as the starboard and I couldn't get enough clearance from the motor to drill that riser....and it really needs to be drilled and tapped for the 1/4" plug. I either need a right angle drill or I'm going to have to remove it to drill and tap. After I drained the port riser I could just push the 1/8" plug back in the hole even with Teflon tape on it to try to get it to thread in.
I have no indications that there is a cooling problem or that the manifolds or risers are bad in any way at all....but the age of them and the amount of junk that came out of the one side makes me wonder if I should just replace them.
Engine: Mercruiser (454 cid) Model MIE 330 S/N 5652430 (straight inboard)
Exhaust manifolds are no longer available: Port 47735A 1, STBD 47736A 1
My wallet tells me not to fix that which isn't broke....but?
My question is should I be proactive and replace the manifolds and risers? If the answer to that question is yes, where do I get them since they are no longer available?
