Exhaust Manifolds
Thomv
Finally started my project removing the exhaust manifolds and risers on both of my motors. One of my exhaust ports was very wet with gasoline. This is my hard starting motor due, to what I believe is a flooding condition. Can I assume my fuel injector on this port is leaking after the motor has been turned off?
Bt Doctur
easy enough to test , remove the injector and apply air pressure at the inlet side and see if it exits.
