exhaust problems?
teamnull
i have a 224 cid 165 hp mercruiser with an alpha 1 outdrive? i have exhaust coming out of the transom plate and very little out of the prop. at all rpm. i was told that the exhaust exits thru the transom at idle and low rpm then out thru the prop at high rpm. told this was because of a flapper in ehxaust tube. they said it probably came apart and lodged farther down the line. flapper was to prevent back flush of water. i was then told it wasn't a big deal to be like that. my thinking is if they put it on at new it should be there now.
Re: exhaust problems?
Ayuh,.... Pull the drive,+ see if you can atleast dig it Out....
I believe it's Replaced from the Top of the Downpipe...
