FreeBeeTony
- Joined
- May 15, 2002
- 3,995
Re: Exhaust Restriction Further Update
The number on the upper is 6835410, can't read any number for the ratio. Will do the prop test tomorrow, don't want to get dirty again tonight. I don't think its a ratio problem, boat does ~22mph at 3200RPM with a 15" prop, boat weights 4000#.<br /><br />I haven't measured the cam yet......you guys think that's my next step? IN the manual it says I may need to remove manifolds to check cam. If that's the case I will probaly wait until I pull the engine.<br /><br />What about this spacer between the carb and manifold? I have the Weber/Edlebrock carb installed w/o a spacer. Should I install one and try that? What does the spacer do?<br /><br />If it is fuel.........how do I do a conclusive test? Should I start investigating different metering of the carb?
