MikDee
Banned
- Joined
- Jun 6, 2007
- 4,745
Re: Exhaust riser plug hole threads
I agree with jason, they don't look that bad to me, I would get them cleaned as best you can, pressure test them however you can, and use them at least for the initial startup to see what you got.
Personally, the 1st thing I would do is take out the spark plugs, and put some Marvel Mystery oil (or any oil) into the cylinders, then put them back in, and let it sit while you did other external stuff, before you ever try to crank it over, then as Don said spin your oil pump over with an electric drill, just before you finally decide to try cranking it.
Don't get discouraged, you've got a nice boat, nothing is that hard to do on an I/O except replacing the starter
most things may require some work, & moderately heavy lifting, and certain procedures to follow, but balancing a starter in one hand, while trying to catch a bolt with the other, laying under the engine at both arms length, is the worst,,, and sometimes it just has to be done.
hmmm not the worst looking ones i've ever seen. If your going to try to save a few bucks and clean those up make sure you run a file over the mating surfaces to make sure they are true.
