UNSUREBOATGUY
Thread starter- Joined
- Sep 14, 2009
- 117
1987 Mercruiser 3.0 Alpha 1
I ordered a new exhaust shutter because I was hearing an intermittent metallic noise towards the aft of the engine that comes and goes with different RPMs. After doing some searching and reading-seemed to be a reasonable guess as to what was making the noise. I was told by a previous owner that he overheated at one point, so I figured I might as well take a look. All I found was the steel rod that goes across the pipe. So, I have a few questions:
1. Do I need to take the drive off again to look for shutter parts? When I had it off this spring, I didn't see anything lodged in the exhaust outlet at the gimble. I tried to see if I could see/feel anything as I looked down the pipe tonight and wiggled a wire around in there. There is nothing that would make me think there is a blockage, except possibly the metallic noise and the fact that the shutter is completely missing. (The metallic noise may have been the piece of steel rod?) The rubber connector hoses look good-they may have been replaced. Maybe the shutter pieces were fished out before????
2. Where do I find the grommets needed to install the new shutter in the pipe? (as seen on page 6C-5 in manual # 10) The old ones were junk.
3. When I put everything back together, should I sand down the pipes to make them smooth so the connector hoses seal better?
4. Also the manual says to put bellows adhesive on the bottom pipe and connector hose where they meet. Is this a good/bad idea? I plan to follow the directions unless there is some serious reason not to. Should I put any sealer on any of the other joints? I just want to do it all right.
Thanks a bunch for your input. Sorry for the long post.
