exhaust tube?
biggjimm
What is the difference between a regular bellows & an exhaust tube? Does the tube just dump the exhaust right at the gimbal housing & not go through the outdrive & prop??? Thanks. Jim.
Yep, you got it
The tubes make the exhaust noise a bit louder when on plane because it does not go thru the prop. Tubes are mostly used with big blocks
