expected speed?
mjc3276
boat... Starcraft 16 ft open aluminum v hull
motor... Mariner 9.9
question what would an anticipated speed be at wot with 500 lbs gear be? the second question have... same setup... would it be worth buying a 25 or 30 hp for the boat? it's rated at 1225 lbs plus 40hp motor.
Re: expected speed?
Hi. A 9.9 on a 16' boat with 1 person and 500 lbs of gear isn't going to break any speed records!
Whether it's worth spending $'s on a bigger motor depends on how far you will be traveling and how much time you want to spend getting there. Obviously a bigger motor will move you faster. Worth it ?? That's your decision ;)
jigngrub
Re: expected speed?
You'll just chug along with a 9.9 under those conditions, I think you'd be much happier with at least a 25 and the boat would perform much better too.
polecat77
Re: expected speed?
I have a 16ft monark I had a 9.9 4stroke and she would do 12 kts put a 30 and same boat would do 33 all GPS
steelespike
Re: expected speed?
The 9.9 is rated for about 20 mph on a light reasonably fast boat.
The plus is your 16ft (if a bare bones model)will plane easier with a load than a smaller boat.
Carefully propped and loaded you might get 15.
No doubt a 25 would be a vast improvement. I believe a 25 is rated for about 31 on a light reasonably fast boat.
Our old gale 25 on a 18 ft Crestliner utility would do 18 or 20 with 6 adults aboard.
3 men averaging about 180 3 women at about 125.On or old small 15ft it wouldn't plane.
roscoe
Re: expected speed?
Have had several similar boats, some light wt, some a little heavier.
20 hp was the minimum to get them up on plane with a 500# load.
30 hp should clip along quite nicely.
mjc3276
Re: expected speed?
I GPS the speed.. 15.6 mph going out and 17.9 back. no wind. tide going out both during duration if trip. . only thing I can think if is a STRONG current. I anchored the front in 10 ft of water biweekly to light wind but I was turned 180 degrees and stayed there regardless if wind ppicked up or not. the prop is OEM.
Campylobacter
Re: expected speed?
Is this with 500 lbs of gear AND you? if so, thats is really good. I would expect numbers like that with one passenger and minimal gear.
